Looking for a chart or the formula
Old 03-29-2007, 08:22 PM
NewYork Art's Avatar
Default Looking for a chart or the formula
Looking for a chart that will tell me the temperture drop and the air flow on the intake.... on how it affects combustion and horse power gain.
Old 03-29-2007, 08:38 PM
SSpdDmon's Avatar
You mean like the formulas the SAE corrections use on the dyno to account for changes in atmospheric conditions?
Old 03-29-2007, 09:06 PM
yes
That should do
Old 03-29-2007, 10:32 PM
SSpdDmon's Avatar
Well, hopefully someone has that. I don't...but someone here might.
Old 03-29-2007, 10:45 PM
RedHardSupra's Avatar
airflow=CYL * RPM/120 * VE * rho * CYLVOL
where rho is the air density, and you can get it with:
rho=1.2929 * 273.15/TEMP * MAP/101.325
there's also a more precise formula that takes humidity into account, but since our cars dont have a humidity sensor, we can blissfully ignore it.
TEMP (in Kelvin!) is a blend of ECT and IAT according to bias tables and airflow amount.
CYL is number of cylinders
CYLVOL is cylinder volume in Liters
MAP is MAP in kPa
Old 04-01-2007, 10:27 AM
P Mack's Avatar
Here is the formula for correction factor http://wahiduddin.net/calc/cf.htm
