Driveshaft for 9 inch Moser in 94 F body
Old 03-30-2007, 05:02 PM
bitemyss's Avatar
Default Driveshaft for 9 inch Moser in 94 F body
Does the driveshaft length remain the same when installing a 9 inch in and F-body? I have a 3 1/2" aluminum with 1350 u joints that I would like to use, but it is one inch shorter then the stock aluminum one I have.
Any info or help would be greatly appreciated.
Old 03-31-2007, 10:41 PM
94Z28Joe's Avatar
I'm currently using my stock steel one broke the 1le one a had
Old 04-02-2007, 11:11 AM
EPP
EPP's Avatar
Question
Yes, the driveshaft length remains the same. I don't think I would use your 3.5" one though if it is one inch shorter than stock. Bob
Old 04-20-2007, 11:51 PM
pyronotic138's Avatar
i just installed a 9 inch and my driveshaft doesnt fit. i need it to be like 1 inch shorter for a guaranteed clearance. with it in the car right now i have about 1/4 inch while its on a lift. and i know your supposed to allow for 1/2 to 3/4. lemme know if anyone has an oppinon on this
Old 04-21-2007, 04:53 AM
EPP
EPP's Avatar
Smile
It is probably because you have the rear unloaded. Put the car on the ground, or jack the rear up, and then the stock driveshaft should fit. Bob
Quick Reply: Driveshaft for 9 inch Moser in 94 F body
