do knock sensors wear out?
Old 03-30-2007, 09:40 PM
Janko98Z's Avatar
Default do knock sensors wear out?
I'm in the middle of installing my ls6 intake on my 98Z and I want to know if I should replace the knock sensors since the manifold is off. They're original with 130k but have never thrown a code. The harness to the rear sensor was crushed flat under the manifold also so I wonder if I should replace it. The sensors are only $40 at autozone -if Wells are decent quality.
Old 03-30-2007, 10:40 PM
gametech's Avatar
They don't wear out, but they break VERY easily.
Old 03-30-2007, 10:46 PM
brad8266's Avatar
no need to replace them.
Old 03-31-2007, 09:39 AM
Janko98Z's Avatar
how fragile is the wire harness and connectors - the harness is flattened from the old manifold and the black caps seem pretty loose.
Old 03-31-2007, 11:10 AM
brad8266's Avatar
Thas fine as long as the wirtes arent cracked
Old 03-31-2007, 11:18 AM
SS SLP2's Avatar
I would replace the wire, pop up the rubber plug which covers the sensors, if they look rusted, I would replace then now, al so you should build a dam around the sensor, I am not sure how to explain how to build the dam , do a search on here for dam around knock sensors
good luck, Johnny
Quick Reply: do knock sensors wear out?
