MS4 cam swap
Old 03-31-2007, 12:28 AM
sprayin'99ss's Avatar
Default MS4 cam swap
I just ordered the MS4 with a 112 LSA for my 99'ss. I was going to do a before the cam and after dyno pulls so we all can have a good look at what it can do! Only other items getting switched out are valve springs, pushrods (will check legth once cam is in car), harland rockers, oil pump, and timing chain, also pacesetters and true duals. The car itself is completely stock except for 42# injectors, racetronix pump, juice, and lid, with a novice hptuner tune. I also ordered a performabuilt level 2 trans with 3500 stall. Any ideas on what you all would like to see in the write up to validate the final #'s or if anyone cares to see the swap #'s?
Old 03-31-2007, 12:15 PM
Z28LS1camaroguy's Avatar
do a write up on how to install the tranny and the converter, i havent seen a writeup for that with pictures yet.
