Axle bearing Install help
Old 03-31-2007, 01:06 AM
Klev's Avatar
Default Axle bearing Install help
Just replaced bolth axle bearings tonight. Passenger side had a good amount of play up and down so i figured i would just do bolth now. Anyway after i had gotten it all back together and on the ground there seems to be a lot of play in and out if i grab a tire and push in and out (on the ground). There is also a noticable sound from bolth axles as well (clunking). I cant think of anything that i could have done to make it worse than it was before, but i didnt not have this much play or the sound before replacing the bearings. C-clips looked mint as well. I know that a small amount of play in and out is normal but it just seems excessive to me compaired to what it was before i did the bearings. Any ideas would be great.
10- bolt, 3.73g, paddle kit (installed by prev owner)
-Klev
Old 04-01-2007, 09:44 PM
88zukon36s's Avatar
the only thing i can think of would be to check the paddle kit.
