Magnacharged LS2 w/ GT2-3...Valvespring advice?
Old 04-02-2007, 11:51 AM
02RedHawk's Avatar
Default Magnacharged LS2 w/ GT2-3...Valvespring advice?
Hey all -
Which Valvespring would you suggest using on an LS2 with both a Magnacharger (7psi) and a LPE GT2-3 cam (207/220 .57x" lift)?
I've narrowed it to two choices, both beehives - Comp 918s or PSI-1511s. (I will use Ti retainers with either)
Comp-918s are 130lbs @ 1.8" and 318lbs @ 1.2".
PSI-1511s are 120lbs @ 1.8" and 350lbs @ 1.2".
(recall that many use LS6-springs with just the GT2-3, and many use LS6-springs with just the SC....but not necessarily a combo of cam+SC)
I know the Comp-918s are sufficient to handle the lobes of the LPE Cam and the boost-pressure from the SC, but spring-longevity and reliability is also of great importance to me. Hence, the reason why I am considering the PSI springs (aka ISKY toolroom springs). I would love to have the springs last 30k+ miles without even considering if their fatigued, and I think the PSIs would offer that best opportunity....However, is the open-pressure (350lbs) waay overkill for my cam/SC combo, and thus put undue stress on the stock lifters (ie, then increase the case of a premature lifter failure)? I mean, there's guys using the PSI springs with very aggressive lobes and lifts greatly exceeding .600"......
Any help / advice is appreciated.
Old 04-03-2007, 04:26 PM
02RedHawk's Avatar
ttt. Anyone?
Old 04-03-2007, 04:38 PM
Grimes's Avatar
PRC duals should be enough for your application
http://www.texas-speed.com/shop/item...d=173&catid=48
Old 04-03-2007, 06:28 PM
02RedHawk's Avatar
Thank-you Grimes for the response, but duals aren't a choice for myself. I prefer the lighter mass and better harmonics of the beehives. Hence, that's why/how I've got it narrowed to the two choices I listed originally.
Old 04-03-2007, 07:08 PM
LPE SS's Avatar
Crazy idea....ever think of checking with LPE? Better yet, check with Ed Potter at LM Speed====>
Ex-LPE staff guy, into fbody magnacharger's and uses that cam in his combo. Either way, you're bound to get the answer you're looking for!
Old 04-03-2007, 09:27 PM
nmp27's Avatar
Go for a duals if you can.
One problem with a single is a big pile of junk parts...
