Tial BOV 9psi or 11psi spring?
Which spring do I need and what is the difference? Dont understand the theory in the different springs.
I have a 01 WS6 installing STS kit with 60-1 and a TRT FMIC kit. TRT sent me a 11psi BOV and in the STS kit I got a 9psi BOV. I know 2 are not needed which one should I use for my kit and FMIC. Goal is to boost and tune around 7 to 8 psi max.
what spring you need depends on the amount of vaccum ur car is pulling.... if you engine is stock, i believe you will want the 11psi spring... However, if you have a larger cam, or something that will decrease the amount of vaccum the engine pulls, then you will want the 9psi spring
