Aftermarket 02 Sensors... What do I need?
Old 04-05-2007, 05:56 PM
DANSBIRD's Avatar
Default Aftermarket 02 Sensors... What do I need?
:help: 130k miles on the stock ones, just got a set of Kooks headers and the car is acting like a raging bitch. Believed to be b/c of the 02 sensors.
Old 04-05-2007, 08:13 PM
DaddySS's Avatar
Don't know what acting like a raging bitch bitch means but you should havit tuned after a header install.
Old 04-05-2007, 10:11 PM
DANSBIRD's Avatar
From what i'v heard, a tune wouldnt be causing it to act like this. bad 02 sensors would though.
Old 04-05-2007, 10:59 PM
horist's Avatar
can you elaborate on what "acting like a raging bitch" means?
Also are you setting an SES light?
Do you have access to a scanner or a friend with a scanner ?
If the O2s are slow it will generally set an insufficient switching code... narrowband O2s run 70+ each, so i'd suggest more info and research rather than potentially throwing the money away
Old 04-06-2007, 07:13 AM
DANSBIRD's Avatar
Iv had the SES light on for some 50k+ miles. I'll see if i can get it checked today again. If I did go w/ 02 sensors, what would be a good brand? and id need extensions
Old 04-06-2007, 07:21 AM
DANSBIRD's Avatar
Its bucking when normal driving. Once i get it up to cruisin speed, it starts kinda kickin and acting like it wants to die, but it never does
Old 04-06-2007, 07:24 AM
brad8266's Avatar
Bosch 13111 They have the additonal length needed on the wires, no extentions needed.
Old 04-06-2007, 07:25 AM
brad8266's Avatar
Tuning is not really needed after a header install. helpful yes, needed no.
Old 04-06-2007, 07:26 AM
RMR JAM's Avatar
definately.
You need to be more descriptive in your post. What year car/mods. Someone near you might can tune out the codes that are causing your SES pretty cheap if they new what you had and what you needed done.
Bosch 13111 o2's and you wont need extensions. And with 130k, I would say change them even if that wasnt the problem.
EDIT: I see Brad beat me to the answer.
Old 04-06-2007, 07:28 AM
brad8266's Avatar
What is with everyone saying you need a tune for headers?
Old 04-06-2007, 07:33 AM
RMR JAM's Avatar
I guess I shouldnt have said "definately". But changing anything that could affect the volume of air going through your engine can affect your fuel trims and a little tuning can get the most out of your mods. That being said. I dont wanna second guess someone with 6000 posts. You will need a tuner to delete the codes for your SES lights though even if they dont "tune" your car.
Old 04-06-2007, 07:39 AM
brad8266's Avatar
Post count means nothing, take that with a grain of salt.
Yes tuning is always the best thing to do no doubt, its just some people get misled when they hear these things, especially about headers. Everyone that has a problem how their car runs after headers is told by people on this site to just get a tune when 95% of the time the real problem is something else such as loose plug wires, cracked plug ceramic, or failed O2 sensors. Headers alone will not cause your car to run all jacked up and a tune will not fix it.
Yeah all a good header install will do it throw your fuel trims around little bit, which most likely wont even be noticed unless you are scanning.
Old 04-06-2007, 10:08 AM
DANSBIRD's Avatar
Thank you Iv mentioned this several times and most of the time, the response is "Oh, you need to get it tuned!". Nooooooo There is something else amiss besides the tune.
Old 04-06-2007, 10:09 AM
DANSBIRD's Avatar
I went to AutoZone and bought the Bosch O.E. o2 sensors. Kooks sent me extensions w/ the headers, but I'm not sure if they're long enough for these Bosch o2s. We'll see.
Old 04-06-2007, 10:11 AM
DANSBIRD's Avatar
Just curious, why wouldnt I need extensions w/ the 13111s? I believe I bought the 13444s or something (It listed as the Bosch O.E. style)
Old 04-06-2007, 11:03 AM
RMR JAM's Avatar
the bosch 13111's have longer wires on them. They are at least 18" longer, maybe more.
Old 04-06-2007, 11:13 AM
DANSBIRD's Avatar
HMmm thanks. I'll take these back
Old 04-06-2007, 11:15 AM
DANSBIRD's Avatar
Are there any modifications needed w/ the 13111s? or just plug them right in
Old 04-06-2007, 11:19 AM
RMR JAM's Avatar
no mods necessary
Old 04-06-2007, 11:28 AM
DANSBIRD's Avatar
The headers came w/ extensions, I THINK. Perhaps the 13444s that I bought plug into the extensions :hmm:
