question on flycutting-pertaining to valve angle
the heads im going to be using have 13.5 degree valve angles as oppsoed to the factory 15. if i use a stock head to cut will that create an issues? im not looking to pull apart a new set of tfs heads just to flycut and i cant get a straight answer on any of my clearance questions so im looking into just cutting the pistons in case.
