Torque converter noise?
Old 04-07-2007, 04:15 PM
nodnarb481's Avatar
Default Torque converter noise?
I dont know if it is but it sounds like its coming from that general area...
I have always kinda heard a sort of whooshing noise like someone rubbing two pieces of paper together whenever I was on the throttle in the lower RPMs but the exhaust noise would overpower it so I would never know if it was higher up too. The noise would also go away when the car went into lockup. It sounds almost like maybe there is a leaf or something between the converter and the flexplate.
So yesterday I had to do some exhaust work.. in the end the car was basically left to catless with some clamps holding it together.. but the exhaust is obviously leaking (its a temp fix as I wait for my new cats because I blew out one of the ones I have now) so now I hear another noise.. a more chattery noise that starts around 1500 rpms and is present in lockup as well.
I almomst assumed it was just the exhaust because it was poorly put back together but its not present in park.. only when driving.
Any ideas?
Old 04-08-2007, 08:28 AM
Ragtop 99's Avatar
So the noise occurs in non-lockup conditions and under lock-up?
Old 04-08-2007, 10:11 AM
nodnarb481's Avatar
well the first noise that sounded like paper being rubbed together was only in non lock-up.. the second noise i describe that just started happening occurs at all times
Old 04-08-2007, 07:05 PM
nodnarb481's Avatar
anyone?
