lt1 edit ???'s tuning ??'s
i spoke to a few dyno shops that are willing to tune my car with lt1edit-if i buy it. a few things they mentioned that is im running my rear turbo setup blowthru and they said my maf might not be able to read high enough. does anybody know if this is true and if it is what is its limit, is there anyway around it ie SD mode. i then asked him about tuning in SD and he said my car has a 1 bar map-almost like i couldnt put in a 2 or 3 bar map sensor. is this true. i guess im trying to figure out some limitations before i have to make several trips to the dyno because i dont have the right setup. my kit is on and done. rear mount t-61. intercooled, meth inj, 42lb svo
Hold out for a shop that has a commercial edition of LT1Edit. If they don't than they are going to be experimenting on you. The guy that does a lot of them will already have invested in the equipment.
It may be more expensive, but you will get it done correctly.
Perry
Perry
