thunder racing gear package
I'm about to purchase the strange 3.73 gear package from thunder racing and im gona get it installed at a local shop and i was wondering if its really worth spending the extra $35 for the deluxe install kit or just stick to the complete install kit which is no extra cost.
The deluxe kit consists of pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals.
The complete kit consists of pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion & carrier bearings
I just installed the Strange 4:10's in my M6 car and its great.... I did the deluxe install kit... figured if I had it all apart it would be a good time....me and my buddy had it all apart and back together in about 4 hours... and it only cost me $35 at the Hobby shop on base for the lift and press..... Overall if your doing an install this is a great kit to go with...
I want to get a set installed and just wondering about how much it's going to cost me?
Originally Posted by shooter
How much did the local shop quote you for your install?
