help with simple pushrod question thank you
224/224 .565 114 lsa cam.
stage 2 cnc heads
would u recomend diffenrent pushrods and whos whould u go with. Would u keep stock length of 7.4 inch
stage 2 cnc heads
Re: help with simple pushrod question thank you
Base circle is reduced on aftermarket cams and ZO6 cams for added lift. The amount can vary but in my case it was .040" on each half of base circle, but my heads are cut .035" so i run stock length pushrods. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
