Lowering Swaybar
Old 04-12-2007, 10:25 AM
52172's Avatar
Default Lowering Swaybar
Does anyone have any pics of what is needed to be done to the end links once a swaybar is lowered to make the swaybar work? Maybe TT? Are there any Hi-Flo cars out there with the front swaybar on? Thanks
Old 04-14-2007, 01:14 AM
Roadie's Avatar
I dropped mine a while back for a different reason... It's a Suspension Techniques 35mm solid bar with poly end links. I used some 1/4" thick x 1.5" flat aluminum to shim it down and used the same endlinks. I don't think it moved the sway bar enough to affect it any. How far are you going to drop it?
Old 04-14-2007, 08:18 AM
52172's Avatar
We need about three inches however if that is too much to lower it we might put a dimple in the turbo crossover pipe and only lower it say 2.5 inches.
Old 04-14-2007, 08:35 AM
MiaSSmaro98's Avatar
ive seen companys run the down pipe under and back up the swaybar so why lower it
Old 04-14-2007, 08:38 AM
52172's Avatar
Its the turbo crossover pipe and its already made and on the car.
Old 04-14-2007, 08:41 AM
Rick Speed's Avatar
We lowered about 1" for our kits and used stock end links... if you space it down 3" then measure the spacer on the end link and go to the parts store and get one with a smaller spacer.
Old 04-15-2007, 08:26 AM
52172's Avatar
Thanks! When you say get one with a smaller spacer you mean a shorter end link?
Old 04-15-2007, 09:23 AM
Rick Speed's Avatar
Yes.. If the end link has a 4"sleeve then just get a 1"sleeve or whatever fits the job
Old 04-15-2007, 09:40 AM
52172's Avatar
Thanks again.
Old 04-15-2007, 10:50 AM
bowtieman81's Avatar
I lowered mine about 1.5" with the TTi kit. Made my own spacers. I am not sure how much you can lower it and not have anything bind up, mine was a bit of a bear to get everything lined up with a 1.5" drop.
Old 04-15-2007, 11:30 AM
52172's Avatar
Yea we are not sure either, but from the pics I have seen of TTi kit it is lowered maybe a little more than two inches and works good. I need 3", but if that is too much we are gonna put a dimple in the turbo crossover pipe and only lower it 2.5 inches. I think when you lower it 3" the ends are in contact with the a arms.
Quick Reply: Lowering Swaybar
