General LSX Automobile Discussion Non-technical LSX related topics.
Do you guys rev-match?
Old 04-12-2007, 02:27 PM
razorclaw99's Avatar
Default Do you guys rev-match?
someone told me that when u downshift, you should kind of rev it up a bit to keep the Rpm's there and save ur clutch. i mean i do it sometimes.only like if i wanna race, so from 50 i rev match into 2nd gear but 5th-4th i usually dont. How many of you rev-match?
Old 04-12-2007, 02:35 PM
Starz T/A 17's Avatar
I always try and do it, when you downshift and your car "jumps" from the increase in RPMs its more strain on the clutch and the whole drivetrain, Im not saying your going to blow your rear from a simple downshift but its more strain, so if you can why not prevent it
Old 04-12-2007, 02:43 PM
SexyTransAm's Avatar
who uses the clutch to down shift??? when i drive a stick i dont down shift with a clutch. try that if u wanna save it
Old 04-12-2007, 02:44 PM
you dont use a clutch to downshift? so u mash it into a lower gear? probably why you're better of with a A4...
Old 04-12-2007, 02:46 PM
ha ha ha if ur good u can do it with out the clutch and still be smoth
Old 04-12-2007, 02:47 PM
mikerulzu's Avatar
I almost always rev match when downshifting.
Old 04-12-2007, 02:56 PM
BananaHead's Avatar
I always do.
stangbangin69's Avatar
like to see someone shift my car smooth like that without utalizing the clutch... it's a pita...
Old 04-12-2007, 02:58 PM
Shinigami2x4's Avatar
Depending on the situation (such as a stop light) i put in N or push the clutch in till a stop, then back to first. however if i am slowing down because of traffic, i shift down to third and it usually never jumps unless im going 45 in fourth then back to third, then it jumps and since i usually not going that fast its not a big deal.
Old 04-12-2007, 03:05 PM
hell id like to try it just to see if i could its a challage to make my self a better driver
Old 04-12-2007, 03:10 PM
Ntimid8r7's Avatar
That is true! I shift my truck without the clutch. I only use it in 1st gear to take off, after that once it gets a certain rpm it will just drop out of gear into the next. Its not for racing purposes... But just puttin around you can do it.
Old 04-12-2007, 03:12 PM
thank you
Old 04-12-2007, 03:15 PM
SHINER's Avatar
you HAVE to rev match when dropping down to a lower gear because the transmission locks you out.
Old 04-12-2007, 03:16 PM
jond99's Avatar
I always do.
Old 04-12-2007, 03:18 PM
Rescue Ranger's Avatar
i even blip the gas to rev match in my accord.. rev matching ftw.
Old 04-12-2007, 03:23 PM
oh, i'm not saying u can't.. i've driven vehicles that you can shift or downshift like that without using the clutch.. BUT my camaro is a totally different animal... my t56 is a pita lol
Old 04-12-2007, 03:27 PM
Super Speed's Avatar
That is until you go from 3rd to 2nd hehe
Old 04-12-2007, 03:37 PM
2000badbird's Avatar
its not hard to shift without a clutch up or down just learn to do it on a beater not your f-body
Old 04-12-2007, 03:39 PM
good call on that 1
KrisXpc's Avatar
I rev match my bike =]
I would do this with my old 6 speed. Sounds Mean as hell to anyone following..
