Bolt Prep for Assembly
What does GM specify for thread preparation on bolts that thread into aluminum. Anti-sieze? Threadlocker? Oil/grease? Different for certain areas?
Threading fasteners that have been thoroughly cleaned (degreased) into aluminum (engine block) is asking for trouble as they will surely gall. Upon disassembly, I noticed what appeared to be some type of compound on the threads of most of the bolts. Something surely must be specified. Sorry, I don't have a factory manual.
Thanks,
Andy1
Thanks,
Andy1
Originally Posted by vettenuts
You are correct, GM specifies something different in each location and the number of places that loctite is specified is few and far between. Usually, when specifying a thread locker, they specify a new bolt.
BTW, few realize that a second primary function of Loctite is to prevent galling. I typically used a low retention grade of Loctite for (non GM) race motor applications that were frequently disassembled. Rarely did I have galling issues in aluminum. I just want to know what GM specifies for the LS1 in a street application.
Thanks,
Andy1
