carbed 5.3
Perhaps I should be more specific:
I am about to swap into my third gen firebird a 5.3 engine. The wiring for FI is daunting, but I love the LsX based engines. All aluminum are too expensive for me so I bought a 5.3 from a junkyard for 500 bucks including tranny (not bad, huh?). So, I hear carbs really let any LSx based engine breathe and are simpler to install. I was curious if anybody has power numbers for said swap including the bore and ported heads, or stock.
i dont know if this helps but carcraft did like 490 at the crank with stock heads a cam n carb on 6.0 LQ4. they also did 550 with the l92 heads. its a series they did over the last 2 months. you should check it out allot of good info. hope this helps
