Car surges (RPMS rise when clutch is in)
Old 04-13-2007, 05:08 PM
2KThunder's Avatar
Default Car surges (RPMS rise when clutch is in)
The rpms raise to 2000 when the clutch is put in like when coming to a stop at a light and take around 10 seconds to fall to normal idle speed. Can this be tuning related? the tunes been looked at a few times by different shops. Im stumped. Car has a 232/234 cam.
Old 04-13-2007, 06:00 PM
96slow6's Avatar
Clean your maf and check your air filter. It seems Like you might be getting a bump in timing becuase your pcm thinks its getting a load.
Old 04-13-2007, 06:10 PM
2KThunder's Avatar
Ive actually swapped MAF sensors and I think the air filter is new as well. Thanks for the reply.
Old 04-13-2007, 09:42 PM
808ws6's Avatar
Change your Throttle Cracker Activate Speed to 15 phm and Deactivate to 13 mph.
Also change the Idle Speed correction time to 2 sec's.
That should take care of it (so as long your idle airflow tables are correct).
Old 04-14-2007, 08:58 AM
P Mack's Avatar
I'd bet the idle airflow tables are wrong.
Old 04-14-2007, 05:07 PM
2KThunder's Avatar
The guys at MTI took care of me. It was partly my throttle body, ive read the Holley TBs tend to be finicky. As far as I can tell all is well now!
