easiest way to remove oil pan??
Well everything was going smoothly and then... took out the stock cam and I hear a "tink" noise. Lifter into the oil pan due to my own carelessness. After alot of cursing I decided to remove the oil pan tomorrow. What is the easiest way to go about doing this wihtout a engine hoist? Thanks and merry christmas!
Matt
Matt
Re: easiest way to remove oil pan??
I would still have to drop the oil pan right? And can I reuse the oil pan gasket? I think the lifter was either # 7 or 8 cylinder. Can you explain the procedure a little more, I can't seem to find much information about the sender unit in my service manual. Thanks !!
