Mobile 1 or is there better oils??
Mobil 1 is not too thin, Mobil 1 "5w30" is too thin If you want to stick with or start using Mobil 1, then use 0w40. 5w40 used to be a very good choice, but they switched it over to the turbo diesel truck, and I am not positive if the formula stayed the same, so to be safe til I find that out, 0w40 is what I use in my WS6 and 5.3 ECSB Z-71.
Other oils that are very good to use are 0w30 German Castrol, which is touted about the best. Also Amsoil 5w40 is a great choice as well.
Just to finish it off, a K&N filter PN HP2006 will allow you to use 6 full quarts, and its a favorite among LS1 owners as well.
