Grinding into drive
Grinding into drive
What would cause my tranny to grind into drive?
Doesnt matter what gear I put it into there is a 1.5 second delay then a grind and then its into gear. Sometimes my Low trac light will come on when it grinds into gear.
I had the tranny rebuild and the builder said it was my exhaust. I believed him for a while till I put the cam in, and the surging would further grind it into first.
The builder I had turned out to be a pretty shaddy SOB and will not see my car again..
Any help would be great guys!
LS1Tech Sponsor
Grinding into drive is a strange syptom . All happens is the forward clutch comes on but untill you let off the brake nothing inside the transmission is moving infact your stopping the input shaft from turning instantly , everything but the pump is stationary and the pump is moving anytime the car is running , If the transmission works fine other wise I would not be so quick to replace. I cant think of anyway possible something could grind going into drive with the brake applied, Now the converter is possible but it should also make the same sound going into reverse if thats the case. I would look around a bit more if I was you.
__________________
You might try unbolting the torque converter from the flexplate and sliding it into the pump, away from the engine and then start the car... see if the noise changes. Obviously it may not be a good test if it only shows up when shifting but it may tell you something...Does it only do this when moving the selector from P to D or R? How does it shift out otherwise? Did the noise show up immediately after the trans installation / repair? If so was the converter replaced at the same time... it is rare for a converter to be noisy intermittantly but I have seen stranger things.
There just aren't too many reasons for a grinding noise in this unit... look at your torque arm they will crack or break welds and become noisy sometimes. Ordinarilly when a transmission is making grinding noises it is not operating properly...
Good luck.
g
Good luck.
g
Good luck.
g
Good luck.
g
It will only do the grinding when I pring the stick from P to D.
If I pop it into D and hit the gas without waiting 2 seconds it will grind harder before it locks into gear.
Im going to drop the transmission this weekend. If it is the Verter ill now. Its being replaced with a much bigger one.
The low trac light that will occasionaly pop on when it grinds is what really confuses me..
