what would it take to run a Tremec TKO600 behind a 6.0L?
There are bells available for that set up. The problem with a TKO is the old fashioned synchronizers. If you don't mind shift speeds at 4500 RPM , go for it. The TKO is lighter( and also lighter duty) and smaller than a T56 so there is a packaging advantage. Also the ratios offered with the TKO are different & limited be sure they fit your set up.
