why wont this work
why wont this work
i have a 99 transam ls1 wth t56---i bought a ram hd clutch kit and a fidanza flywheel...the pressure plate does not have a dowell hole in it for the pin in the flywheel any one else have this problem or any ideas what to do about it???
LT1 engines are externally balanced. That means the flywheel has to be installed in a particular relation to the engine so it's "heavy spot" counters the heavy spot on the crank in the engine. The dowel is used to make sure that happens. LS1s are internally balanced, meaning the crank is already balanced and everything connected to it also needs to be balanced (referred to as neutral balanced). Sounds to me like you have an LS1 flywheel. If you bold that up to an LT1 engine your bottom end is going to try and shake itself to pieces and probably do quite a bit of damage.
