need help keyless remote
i bought a used remote from a friend of mine and im having a hard time programming it to my car.. bought a new battery and dont seem to find a thread to help me out with this.. anyone out there let me know ok thanx
Sure the remote is good/right one? Plug the FCCID into here: http://autotechs.com/fcc/fccidsearch.htm
Try this... works for me..
98 - 02 Camaro
Have each transmitter you intend to match ready for the
next steps. To match transmitters to your vehicle, do
the following:
1. Turn the ignition key to RUN, then to OFF.
This will disarm the content theft-deterrent/alarm
system (option).
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your instrument panel. See Fuses and Circuit
Breakers in the Index.
3. Turn the ignition key from OFF to RUN three times
quickly (within five seconds). The vehicle will respond
by locking the doors, unlocking the driver's door and
releasing the hatch. Your transmitter is now ready to
match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing
the buttons.
the following:
system (option).
the buttons.
