NEED HELP!!! engine brite foamy engine cleaner
so i did the engine brite foamy clener on my ls1 this morning now stuff is turning white why? and how the hell do i stop it???
I used the same stuff. Did you use it as a polish to when you were done cleaning. (leave a thin spray after rinsing it.) When I used it I just sprayed the hell out of the engine and let it sit for like 20-30 mins then rinsed it clean for about 10 making sure to soak everything that I sprayed. I was carefull not to spray the computer with the degreaser and took it easy around the fuel lines and stuff. I would try and rinse it off more. did you run the car after you were done for like 20 to burn all of the water and gunk off?
yeah i rinsed everything but when it dried it turned all the black stuff to a milky white i just got some mothers back to black and went to town on it its looking better....
