Conversions & Hybrids - Bowtieoverdrive's 700R4 / LS1 "TV Made EZ" kit
Eskimo
04-24-2007, 08:53 AM
I've got one, new in the box.. Sells for $140 + S&H, I'll sell it for $100.
I bought it, and then decided to use a full manual VB, which doesn't require a TV cable.
http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=225
(Figured this would get lost in the general FS section)
Eskimo
12-25-2007, 09:35 AM
Ttt...
schwoch1
12-25-2007, 11:56 AM
PM Sent!!!
LS1MCSS
12-25-2007, 07:56 PM
I bought one once and learned the hard way about which throttle body they wil fit. They will only work on the early throttle body side plates.
Eskimo
12-25-2007, 09:50 PM
I have a TB from a '01 silverado, and it fit up to the TB cam just fine.. how early do you mean?
LS1MCSS
12-26-2007, 06:27 AM
The 00 and up LS1 throttle bodies have the larger side plate and it won't fit them. If you look at the two bodies in the links, you can see the difference in them. One way to tell, at a quick glance, is the spring color. On the larger side plate model, it's a blue spring. That TV kit will work great on the smaller side plate models.
http://cgi.ebay.com/ebaymotors/5-7L-LS1-LS6-GM-Chevy-Throttle-Body-GTO-5-3-6-0-Vortec_W0QQitemZ280186295024QQihZ018QQcategoryZ335 58QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://www.bowtieoverdrives.com/Instructions/LS1.pdf
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
