Wastegate flange
Wastegate flange
Just bought a crossover with a 44 mm WG flange will a 38mm WG work on it as well or only a 44mm WG. I think the 38mm WG will be all I need, that's why I'm asking.(I can that money elsewhere then).
Thanks Nick W
Thanks Nick W
just cut it off and weld on a 38Mm flange
they dont have an adapters that i know of ( i work a lot with turbo systems)
if you have a hks 40MM gate style flange, hit up ATPturbo.com and get the 4 bolt to 38MM adapter, its a plate with countersunk holes and a 2 bolt tapped that allowed you to retrofit.
My biggest suggestion, cut off the old flange, weld on a new one.
