Drill Mod question....?
Hey guys, I'll be getting a new clutch setup for the 5th time anyways my question is....
I had the drill mod done the last time my car was in the shop getting a new clutch put in... Since I'll be replacing the clutch again and various other parts while i'm in there... does the drill mod need to be done on any of the new parts? I only ask because i forgot where the restricted hydralic line was located and on what part since i had it done a few years back...
Thanks!
Thanks!
The drill mod is done to the steel braided line that goes into the master cylinder. If you are buying a new GM master cylinder, I believe the line is included (and pre-bled) so it will need to be removed and drilled through, or just swap the old line on if you wish.
