Pro 5.0 shifter rebuild kit.... where to get one?
Old 04-28-2007, 12:43 AM
Avengeance's Avatar
Default Pro 5.0 shifter rebuild kit.... where to get one?
I just did a clutch swap in my SS and when I removed my Pro5.0 I noticed the bushing between the top and bottom was all worn out.... letting grease get through from the top to the bottom.
Ive already had to replace the springs so it would self center to the middle on the 2-3 shift.
Is there such a thing as a Pro5.0 rebuild kit?
Thanks......
Old 04-29-2007, 03:21 PM
396D1SS's Avatar
i know brand new they will let some grease between the ball. are you 100% sure its worn out?
Old 04-30-2007, 09:14 AM
ghettocruiser's Avatar
Maybe just repack it with new grease? Its possible that the heat from the trans and constant use broke the grease down some and its not as "sticky" as it used to be. I know mine brand new had some of that white grease it comes with coming down through the bottom. But it seemed to be silicone based and really sticky. Figured it would stay up in the main body.
Justin
Quick Reply: Pro 5.0 shifter rebuild kit.... where to get one?
