TH350 Help: Needing Part number for the transmission mount plz..
Im in the middle of doing this now and i was wondering what the part number for the TH350 transmission mount was. The guy at advance gave me one but it was way to tall and the crossmember was all jacked up in the front. So if you know and could either tell me the part number or what to ask for then i will greatly appreciate it thanks.
One for a 1977 camaro is about the shortest you will find, should bolt right up. I've seen people put spacers between the frame and trans crossmember to lower it, same as a shorter mount would.
