Dimmer Fuse (arrg!)
Dimmer Fuse (arrg!)
My interior lights are out. I am trying to find the problem but I can not. The fuse is getting no power. When I jump the fuse off another fuse, the lights work fine. Does anyone have a diagram or anything that can help out of the dimmer fuse.
Originally Posted by WhiteBird00
Dash lights or courtesy lights? The DIMMER fuse gets power from the TAIL LPS fuse so you should check that. The courtesy lights are powered by the BCM.
Dash lights. The courtesy lights work fine, also the tail lights are working so I think that fuse is good.
