daytime running lights
Go from underneath, there is a flap that is being held up by a couple of screws, the light is held up by 3 screws I believe, remove those. Reach up and grab the socket, twist and pull up, remove the bulb and repeat to put it back on. Doesn't take long at all and less hassle than removing the headlights. But I've heard good things about both methods. Good luck.
thanks for the help...hoping everything will go smooth tomorrow....ima try from underneath first.....gonna be a bitch without a jack or rhino ramps though....any other suggestions?
