no oil pressure!?!?
no oil pressure!?!?
hey guys i just did an l67 swap in a camaro i was wondering if theres anyway to prime the system on that motor, i put in a 98 gtp motor and have no oil pressure, i just dont really wanna tear of the front cover to repalce the thing! anything would help, ideas, suggestions? thanks-
blake
blake
did you put in a high volume oil pump? if so you must have pinched the oring from the pick up tube. or you if you swaped the whole motor, you broke the sending unit behind the intake manifold.
