AFR 205's milled to 60cc /G5x1...opinions?
Old 05-07-2007, 03:32 PM
erikthegoalie's Avatar
Question AFR 205's milled to 60cc /G5x1...opinions?
I am narrowing down my new set up..
looking for better driveability and torque from what I have now...MS3/PRC 5.3 heads....
dont get me wrong, this combo makes for some great top end power...but it is not efficient...and is really top end, something I should have expected but overlooked (got caught up in the BIG cam hype)
Wanted to know what ya'll thought about the combo in the title and if you think it'll need flycutting...
Thanks
Erik
Old 05-07-2007, 03:37 PM
Kryckter's Avatar
Have you thought about just swapping out the cam instead of changing the entire setup.
May take a look at the TSP Torquer V.3 cam. You may lose some top end HP, but gain more torque and HP down low.
I think you can do a simple cam change to obtain what you are looking for, just my .02
Old 05-07-2007, 03:39 PM
SSwt00SS's Avatar
i agree, just stepping down to a Tv3, Tv2 or a TSP 231/237 would make you more happy/pleased and spend way less money in the long run...
Old 05-07-2007, 03:43 PM
I already sold the set up, but that is not to say that I cannot buy the same heads again...I know that sounds dumb, and it is lol--I will just leave it at that...
Let's assume the $ is not a factor...
Erik
Old 05-07-2007, 03:47 PM
I like the idea of the smaller runner on the AFR's by the way...
Erik
Old 05-07-2007, 04:05 PM
YellowToy/A's Avatar
If you dont have fly cuts, make sure u have P/V with the cam. A 224 228 will fit but not sure how much more. Look at DRC for torque numbers. 9 is a good number. Smaller cam bigger DRC. I like the AFR alot more that the PRCs. But more money PRC are good .
Old 05-07-2007, 04:08 PM
Stang's Bane's Avatar
There is so much wrong here I am not even going to begin to try....
Old 05-07-2007, 04:09 PM
Kryckter's Avatar
If you do go with the AFR heads, for whatever reason, I would try and get a bigger cam then the G5X1.
If you really like the LG cams, then a G5X3 would fit the setup well, or I would still recommend a Torquer V.3 cam from TSP. The Torquer cam + small runner heads = Torque happy setup!!
Old 05-07-2007, 04:57 PM
Super Hulk Smash
JakeFusion's Avatar
TFS 215s and a G5X3-112.
Old 05-07-2007, 05:12 PM
Sudz's Avatar
Erik
I told you already, DO yourself a favor go forced induction, a d1sc setup with a mild cam say 220/224 is gona make way more tq, hp all across in every rpm.
Old 05-07-2007, 05:32 PM
pdd
pdd's Avatar
Erik
many people do id go with the afr's and a 230ish cam. setup yr dcr for 8.5 - 8.8 and scr 11.1 to 11.5. my setup is in my sig. its driveability is great, has great low end punch and is an absolut screamer at WOT
Old 05-07-2007, 07:42 PM
ProjecT 9's Avatar
My personal opinion for a street car is to run a cam between 224/228 to 230/232 duration.
thats what I think is a good size for a daily driver and doesnt compromise drivability. get some nice heads and run a higher compression with a cam in that duration range and i think you will love the drivability. patrick and tony M. have proven you can make killer power with a 224/228 setup right.
Old 05-07-2007, 09:49 PM
ls2 bait's Avatar
my t2 is still a top end type cam. i say go with the likes of the 228-230 range. that 228/232 cam u looked at before really is a nice cam.
Old 05-08-2007, 01:15 AM
thanks fellas...all points taken..
FI is out of the question because of $$$....I mean, it is not even on the same level as what a good h/c set up will run me...
I LOVE the idea of FI, but need to get a degree first
Old 07-23-2009, 08:01 AM
matt1289's Avatar
I like my small cam, althought I wish I would have gone closer to the 230ish size.
Old 07-23-2009, 08:18 AM
LSX Mechanic
Damian's Avatar
You'll have plenty of room w/ 60cc. I've ran that cam on 59cc heads before and still have .090 clearance on the intake.
That's an AWESOME cam, probably the best all around 346 cam out there. You'll like it a lot.
Old 07-23-2009, 02:54 PM
SS DNA's Avatar
I would say go wit hthe AFRs 205s. Thats what I will buy down the road.
Then I say go with Mamos bigger cam. I think its a 228/232. Try to get a hold on Tony. I know that combo will make GOOD power and the area under the curve will make you very happy.
Do some research on that combo.
Old 07-23-2009, 02:58 PM
Rossi396's Avatar
I think the bigger Mamo cam you're referring to is a .234/.238 - .595/.605. AFR part number is 6017...
Rossi
Old 07-23-2009, 03:14 PM
blu1's Avatar
this thread is from 07 folks...
Old 07-23-2009, 03:21 PM
Rossi396's Avatar
I can't tell you how much I laughed when I read your post, blu1...!
Guess I should have done the following:
Quick Reply: AFR 205's milled to 60cc /G5x1...opinions?
