procharger track results!!!!!!!!!!
what kind of track times can i get out of this setup.it is a vert and a m6.all openion's will be appreciated.i'm thinking it should be in the high 10's.
Procharger P1-SC Twin intercooled 7psi polished air box
45lb injectors
100psi fuel pump
Deablosport programmer
Dual friction centerforce clutch
Dynateck 1 ¾ to 1 7/8 long tube headers ceramic coated
Custom Y pipe
S.S. magnaflow, flow through muffler
Snow performance Water/Methanol Injection sys.
KYB adjustable shocks all 4 corners
Eldibac lowering springs all 4
Rk sport traction bar.
All rear linkage replaced with aftermarket
Cromoly Roll cage(added 100lbs)
45lb injectors
100psi fuel pump
Custom Y pipe
