Going with the TFS Heads, Will Pacesetter long tubes be ok?
My Brand New setup consists of the following?
347 Short Block, Forged rods, Forged Pistons & Arp bolts, Stock Crankshaft
Stock FAST Intake
Nick Williams 90 TB
TFS Heads 62CC Compression Ratio
548-552 @ 650 lift on 112 Lobe Sep
42lb injectors
Pacesetter Longtubes
TSP True Duals
4L60E Yank PT 4400 Converter
Will the Pacesetter Longtube Headers be to small on this setup. I plan on staying N/A for a year & trying to get the car down to 6.60s on motor before I spray the car.
Come next year in 2009 I will add my Turbo 400 Trans & 12 bolt Rearend & seperate Fuel system & then upgrade to some Kooks Headers?
Thanks guys
Seb
Stock FAST Intake
Nick Williams 90 TB
42lb injectors
TSP True Duals
Thanks guys
Seb
Pace Setters will be fine, TSP has ran them on a 10 sec 1/4 car.
It's a good header, and unless you were going F/I or upping the cubes to the point a steped or 1 7/8th header would help, I dont see reason to swap myself.
