how much hp can a stock ls1 take?
Old 05-09-2007, 12:41 AM
THEhomelessONE's Avatar
Default how much hp can a stock ls1 take?
when i say that i mean reliably, dont know much about american engines, thanks, i have 2500 to get a cheap turbo kit off ebay or i can get 5500 by augast?
Old 05-09-2007, 12:43 AM
BigBenz's Avatar
dont get a cheap turbo. get a ati procharger. and i hear about 500rwhp is the safe limit. dont get a cheap turbo.
Old 05-09-2007, 12:54 AM
BIG BAD BLACKSS's Avatar
5500 isnt tooooo far off the price of a procharger kit from bob at EPP, youd need a bigger fuel pump and injectors too though , and you should pin the crank too in my opinion. Your looking at around 7-7500 bare minimum with misc stuff you will end up needing that you wont expect.
Old 05-09-2007, 12:57 AM
slowredz's Avatar
If thats all you have to spend on forced induction then turn around and run and TRY not to EVER look back in this section again for your own good
Old 05-09-2007, 12:58 AM
BigBenz's Avatar
Buy i newkit from BOB. I wish i sure would have, I ended up spending more all said and dont for my used kit.
Old 05-09-2007, 01:13 AM
i saw an episode on spike when they were talking about the procharger, lol im still used to the import price range, so would 4gs be enough just to build the engine? id rather be safe than sorry if im spending over 3000
Old 05-09-2007, 01:15 AM
10,000 if i wait until october, and if i race a few of my friends for money here and there, they are still into 4cyls and staying under 220hp lol
Old 05-09-2007, 01:16 AM
BigBenz's Avatar
plan on spending 7 grand. If you plan on it it will make life a whole lot easyer.
do it the right way with nice good stuff from EPP
Old 05-09-2007, 01:17 AM
ok, so 7gs will be enough to build the motor and a turbo or procharger?
Old 05-09-2007, 01:23 AM
BigBenz's Avatar
7 gs will be enuff to put a supercharger on it. If you want a build motor that a whole new world.
Old 05-09-2007, 06:19 AM
2001WS6Vert's Avatar
From what I've seen here 500 can last, 600 doesn't last long, 550 is walking the edge.
Old 05-09-2007, 10:06 AM
93formto98T/A's Avatar
You could get forged rods and pistons for your stock motor and install ARP hardware and some stock 317 heads for ~2K or less then the motor would be good for 850+hp.
Old 05-09-2007, 11:32 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
New forged shortblock $2900
Stock 6.0L 72cc Heads $350
Valvetrain $350
Procharger kit $6000
Tuning $500
Fuel System using stock lines $1000
Miscellaneous $1000 easy
That should get you well into the region of breaking everything else
Drivetrain: $$$$$
it never ends lol
Old 05-09-2007, 12:38 PM
D-Webz's Avatar
I got a D1SC tuner kit with everthing I need for around 6300 from bob. He has a packaged deal on his website for DIY Procharger kits that I took advantage of.
Old 05-09-2007, 02:04 PM
NemeSS's Avatar
unless your looking for over 600- 700 rwhp full time
i wouldnt bother with a FI motor
for 7k$ u can build a mean N/A motor that will put u over 500rwhp
if properly built.
can always throw on some spray if need be.
Old 05-09-2007, 02:11 PM
LS1speedy's Avatar
When you all say 500hp you mean flywheel horses, right?
Old 05-09-2007, 02:14 PM
landstuhltaylor's Avatar
no, we tend to only use rwhp numbers here. its a much more common measurement as you dont need to take the motor out.
Old 05-09-2007, 02:59 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I'd say 500-600rwhp with a stock engine down to the head bolts. But at the higher levels all bets are off. I'd at least do head studs if I really pushed one.
Old 05-09-2007, 03:05 PM
MrDude_1's Avatar
nope.. we're all talking power at the wheels.
Old 05-09-2007, 05:51 PM
yes im talking about to the wheels, sorry for not stating that before, how much would it cost to fully build the engine for boosting? or if i got a shop to do it all?
Quick Reply: how much hp can a stock ls1 take?
