How to hold flywheel during removal/installation
I just turned the ratchet to the right angle relative to the flywheel so that when pressure was applied it didnt turn the flywheel. Just turn the ratchet at an angle that wont have the force of the ratchet inline with turning the flywheel.
Or just put a socket on the crank bolt, 24 mil i believe and hold it that way, lol
You should be able to get a regular box-end wrench on the bolt and give the wrench one good rap with a steel hammer and the bolt should break loose, if you do not have access to an impact wrench.
