cam gurus, please chime in
for my 383 build i narrowed it down to two custom cams that have been prescribed for me (239/244 .649/.612 on a 112+2) and the (238/240 .605/.609 on a 112+2) now just by looking at the cam specs: do these cams seem like they would have peaky power or more hp under the curve? which would you choose and why? i called comp cams cam help hotline, and that gentleman said id be best with my original cam from my 346 (the torquer v2) which i was told would not be big enough. any insight?
What are your goals for the car?
ok, in my opinion the 239/244 is way off.
Your choice should be between the Torquer 2 and the 238/240.
The torquer 2 will make slight more midrange and have better driving manners while the 238/240 will really take over after 5500 rpm.
I see the tq2 making peak Hp @ 5600 rpm peak tq at 4400 rpm
the 238/248 will peak around 6000rpm and carry. peak tq at 4600rpm
my goals for the car is to gain lots more torque than i previously had. which should be no problem with the added cubic inches.. i liked the drivability of the tq2 when it was in my old set up. i dont really run the rpms up too much seeing that the car spends 95% of the time on the street. and 90% of that is just for cruising (the wife likes going along, a.k.a. i cant play too much with her in the car) but when i do get to the track i dont want to fall on my face in the 1/4 mile. i want my cake and eat it too damn it ! lol ok so im being greedy. but hey, if im paying for it, i may as well make as close to what i want as i can. i think power under the curve is very important, more so than peaky power. id like a continuous pull through all the gears if thats possible
The 238-248 will behave like the tq2 did in your 346 as far as driveability.
From what you described it would be your best choice. Any reason for not getting a Custom Cam Spec'd for your combo?
Originally Posted by SSdreamz
those two cams are custom cams speced for me, the 239/244 was speced by Pred Z. and the other was speced by Patrick G
LS1 Tech Administrator
With the excellent exhaust flow of the AFR heads and the long tubes with off road exhaust, you will not want or need to spread the exhaust lobe too much when running the LS6 intake. If you were running a FAST 90/90, then you could either go 2 degrees smaller on the intake (for more low/mid range punch) or go 2 degrees larger on the exhaust (for more top-end power).
But when running a 383 with the LS6 intake and excellent exhaust, a small split or even a single pattern will work great!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
