LS1 Coolant Temp
LS1 Coolant Temp
What wire on a LS1 F Car does the Colant Temp Gauge get it's signal from? I have it traced in the Harness from the Sensor, but which wire actually sends the Signal to the Gauge..how is the Gauge wired?
Coolant temp sensor
Hi
Just get another sensor and screw it into the plugged port at the aft end of the RH head (LS1 LH head is "swung 180" and mounted on the RH). Then wire to your guage on the dash. The port is M12x1.5
We did this on our E30-LS1 swap. We had to drill & tap the existing port in the RH head for a BMW temp sensor (9/16-18 -- I thought those guys were metric) and then ran a wire to the dash guage. The existing sensor in the LH head still goes to the PCM, with no changes. This worked for us because our sensor is a 1-wire type that gets power from the dash and completes the electrical circuit by being grounded at the RH head.
If your sensor is a 2-wire type (power from battery source, thru sensor, to guage, then from guage to ground), just wire it like that.
Steve & Garret building the 357is
Anyone?
