Driving without one rocker arm for 1 mile? ok?
Old 05-14-2007, 08:32 PM
Mazdryk's Avatar
Default Driving without one rocker arm for 1 mile? ok?
I found out that one of my rocker arm bolts broke off. I was wondering if it would be ok to take out the rocker arm and the push rod and drive the car 1-2 miles to a local shop? Should I also disconnect the spark plug wire and wire to my injector for that cylinder? Whats the worst thing that could happen to the car?
Old 05-14-2007, 08:35 PM
motorbuilt's Avatar
If its the intake rocker arm itll run decent, just pull the pushrod/rocker. Unplug injector too
If its exhaust rocker, itll pop back through the intake but you could technically still drive it.
You wont hurt it
Old 05-14-2007, 08:37 PM
fastlt1's Avatar
Take the plug out.
Old 05-14-2007, 11:04 PM
motorbuilt's Avatar
No, dont take the plug out...no reason to run it open head.
Old 05-15-2007, 12:06 AM
Blk97WS6's Avatar
Originally Posted by fastlt1
Take the plug out.
Yeah no reason to take the plug out, just disconnect the plug wire.
Old 05-15-2007, 02:13 AM
Mazdryk's Avatar
If i disconect the spark plug wire what happens to all the fuel being dumped into the cylinder? Im just worried about it hydro locking.
Old 05-15-2007, 03:26 AM
PREDATOR-Z's Avatar
Sh*t, I would push it 1 mile (1600 meters).
Old 05-15-2007, 04:51 AM
vettenuts's Avatar
Disconnect the injector.
Old 05-15-2007, 09:13 AM
Blk97WS6's Avatar
Yeah gotta do that to. It was already mentioned before i posted so i didnt think i needed to repeat it Sorry for the confusion.
Old 05-15-2007, 02:23 PM
BIG BAD BLACKSS's Avatar
Unplug the injector and pull the rocker/pushrod, done.
Or stop being lazy and get some buddies to help push. I pushed my car home 3 miles myself once.
Old 05-15-2007, 02:25 PM
Blackboosted2's Avatar
I dont see why it's worth the risk, if it's too far I'd call the local tow company and hand then a $20 bill to move it a few miles
Old 05-15-2007, 03:07 PM
TheLS1Kid's Avatar
Have a buddy pull it with a truck while you are steering it.
If its not running the brakes wont work very well so just go slow.
Old 05-15-2007, 03:58 PM
motorbuilt's Avatar
Risk? You guys are kidding right. Its a broken rocker bolt, not a huge risk.
You could drive it 1000 miles without the pushrod/injector/plugwire on and it would be fine.
Old 05-15-2007, 05:45 PM
styoung's Avatar
i would push it or tow it. ive walked 20 miles in the snow so i would be able to push a car 1 mile to be safe.
Old 05-15-2007, 06:02 PM
1BDWS6's Avatar
Kinda what I was thinkin.
Old 05-16-2007, 03:02 AM
cowboysfan's Avatar
or you could make it worse!!!!! its a chance, are you willing to risk it??????
not me
Old 05-16-2007, 03:28 AM
PREDATOR-Z's Avatar
Really? and what happens to the lifter that has no preload on it bouncing up and down freely. (assume it doesn't catch in the cup)
Man, please when you give advice, think before you spill the beans.
change of thought is innevitable
Old 05-16-2007, 03:46 AM
1BDWS6's Avatar
Well then, since you brought it up, EXACTLY what will happen to that lifter that has NO pressure on it as it rides on a roller on the cam lobe inside a cup that keeps it alligned???? Its a freakin mile or 2, its not like he asked if he could drive it on a road trip.....
Old 05-16-2007, 05:30 AM
PREDATOR-Z's Avatar
You tell me,
Guys, please quit this Gung Ho attitude; one simply doesn't run a 8 cyl motor on 7 cylinders on purpose.
Good advice is get help and tow or fix and drive.
Old 05-16-2007, 06:35 AM
1BDWS6's Avatar
I appologize if I came off with an attitude, all I'm saying is that it will not hurt anything to do it for a very short period. Is it good for an engine? No, but neither is N2O or drag racing but we still do it for very short periods. NASCAR engines lose cylinders all the time and still continue on to finish the race.... That is all.
Quick Reply: Driving without one rocker arm for 1 mile? ok?
