My Hatch all of a sudden stopped working??
Well i went to open my hatch yesterday and it didn't do anything usually it will pop a lil and then ill pull on it and then hit the button again and it will pop up. Well i went and got the Key fob thinking it would open it and it did nothing as well.
I checked to make sure it didn't come unplugged and it was still plugged in so im clueless as to why it wont open. Anyone have any ideas????
I have a bone stock 02 and mine does this as well. I think its a common problem. I believe at installunivercity.com there is a right up how to add a new spring that will make it pop right up.
i know mine requires i press the hatch button twice to open, but if your is a mechanical problem, ordering a new actuator/spring should do the trick if you cant trace an electrical issue GL
