how long does it take to swap heads????
Old 05-16-2007, 05:59 PM
maddymac07's Avatar
Default how long does it take to swap heads????
how long is it taking to do job
Old 05-16-2007, 06:05 PM
3.4camaro's Avatar
www.ls1howto.com
Old 05-16-2007, 06:57 PM
Moderator
davered00ss's Avatar
4-8 hours depending on you.
Old 05-16-2007, 07:10 PM
dnm12's Avatar
try looking at page 8 of my website to see what is involved
Old 05-16-2007, 08:06 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
It all depends. If it's your first time, I'd read up, read some more, print out a couple of the how to's so you have pictures and references, and it will probably take you a solid weekend. I found the how to at www.ls1howto.com very thorough and helpful the first time I tackled the task on my own.
I reccomend you take your time and not try to rush it, or else you'll be on here putting up posts begging for help or posting about something that went wrong. If you are worried about getting the car back up and running because it's a daily driver and you need to go to work on Monday, line up a rental car just in case. Trust me, it's cheap insurance if something doesn't go as quick as expected. $25-$35 a day for a rental is a heck of a lot cheaper than having to pay to have your car towed somewhere because something happened because you were rushing.
Once you've done it a couple times, you can get the whole procedure down to a one day job. If you think you'll ever have to do it again, get mls gaskets and head studs or at least ARP's bolts. One of the toughest things about an F-body head swap is doing the torque to yeild head bolt sequence specifically on the rear bolts. Going to ARP's eliminates that, you just need a torque wrench and the proper torque sequence.
Good luck, it's a 3 out of 5 wrench job the first time and 2 out of 5 subsequent times. Just don't rush cleaning out the bolt holes or else you run the risk of either floating a head or cracking the block.
Old 05-16-2007, 08:10 PM
crainholio's Avatar
It really depends on your mechanical skills and tool inventory.
I've evaluated your mechanical skills and shop tool inventory, and calculate that it will take you exactly 22.425 hours to swap your heads.
Old 05-16-2007, 09:26 PM
maddymac07's Avatar
well i'm lookinf for someone to do it who is a mechanic . but i dont want to pay 10 hours of labor if job only takes 5
Old 05-16-2007, 09:35 PM
crainholio's Avatar
Call around, get estimates and comparison shop. Head swap is pretty much a flat-rate job for a shop that does this type of work, not an hourly-rate thing where they're feeling their way around the process. Asking here doesn't accomplish anything useful for you.
Old 05-17-2007, 12:03 PM
MPHmotorsports's Avatar
That is 100% correct. Many shops charge around 10 hrs as a flat rate. It dosen't matter if it takes them 15 minutes.
Your paying for the job not the Hr. If they charged by the Hr many shops would be too inconsistant. One shop might take 22 hrs while the other takes 7 hrs. Or Joes car might take 15 hrs but Brians went smoothly and took 9 hrs.
