c5_ls1_6spd
05-16-2007, 10:38 PM
My c5's rear turn signals don't come on, the rear brakes lights don't come on when I hit the brakes and the reverse lights don't come on when I put the car into reverse. Everything in the front works - The headlights work, the front turn signals work, etc. What could be the problem?
~JOSHUA
05-16-2007, 10:43 PM
I'll ask one of the techs tomorrow, maybe I can point you in the right direction...
You've checked all the fuses right? duh.
c5_ls1_6spd
05-16-2007, 11:12 PM
I checked a couple of fuses (like 5 of them), they were all good.
Here are the codes the car is throwing:
B0502 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B2482 Backup Lamp Relay Circuit
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
