Trans stuck in 3rd
Old 05-17-2007, 04:38 AM
venom ws7's Avatar
Default Trans stuck in 3rd
I wanset racing or anything just normal cruise and my 3rd gear just stuck.
What do guys think I was having problem with clutch when I hit it peddel stuck on the floor.
Btw I just recived SPEC CLUTCH ,01 Slave and Ram master cylinder.
So what to do?
Thanks in advance.
Old 05-17-2007, 06:40 AM
calhoon's Avatar
Do a search for a worn 3/4 shift fork. It is well documented....you need an iron 3/4 fork.
Old 05-17-2007, 08:01 AM
wrencher
wrencher's Avatar
Well if you need to put the clutch in, freshen the trans up while it is out.
The poor clutch releasing/sticking took its toll on the trans. Time to upgrade.
Like calhoon says iron 3/4 fork ,& anything else worn.
Might be wise to upgrade 3/4 billet sliders & bronze shift fork pads.
Might want to do the blocker rings as well, so your basically looking at a trans overhaul.
My advise would be to do it up right while your in there.
Old 05-17-2007, 03:55 PM
Oneslowz28's Avatar
I agree with both of them. make sure you spend the extra money to upgrade everything youll be kicking yourself later if you have a problem.
Old 05-17-2007, 11:24 PM
venom ws7's Avatar
Thanks for the help guys.
