Should DTC0108 MAP High/Low cause a no start?
So, My car was running just fine. Just needed to put the gauges in. I had to patch into the VSS signal wire for the speedo, but that's about the only PCM related thing that changed. After gauge install, no start. Crank, crank, crank, occasional sputter, but nothing.
It is showing a DTC0108 code. Doesn't seem like this should prevent the car from starting though, right?
