How much for clutch and flywheel install?
Old 05-21-2007, 10:51 AM
Deep Blue's Avatar
Default How much for clutch and flywheel install?
Need input quick. The car is in the air having the master and slave cylinders done. The tech says he noted hot spots on one side of the fly wheel that may indicate something is misaligned. The wear on the clutch itself is only about 40%. He recommends replacing the clutch and flywheel since the tranny is already torn down. How much should they charge since the transmission is already partly disassembled?
Thanks,
Old 05-22-2007, 07:48 AM
teke184's Avatar
i would think an hour's labor at most.
all it takes is a few minutes to unbolt and rebolt the flywheel and PP.
Old 05-22-2007, 12:42 PM
Deep Blue's Avatar
Thanks Teke184. They said no additional labor but I am finding a wide range in the cost of clutch kits
Old 05-22-2007, 03:08 PM
greenherb's Avatar
no labor .... do it... upgrade to at least a ls2/7 clutch
Quick Reply: How much for clutch and flywheel install?
