antifreeze leak!
antifreeze leak!
I have some antifreeze leaking from somewhee im not sure yet... but it only seems to leak when its sitting there turned off... if anyone knows whats going on please help.... thanks
Fiery Features Director
Have you checked the hoses, clamps and around the head gasket? Check around the water pump also. Do you see smoke coming from the tailpipe when you start the car? Is there an odor of antifreeze coming in from the vents or inside the vehicle?
I mentioned that because someone else was having issues a while back with a strong smell on the inside of the vehicle. He assumed it was coming in through the vents but the leak was actually running down the back of the firewall (under pressure) and causing the strong smell inside the vehicle. That would narrow down the location of the leak.
