motor pics w/ BECK intake (almost finished)
waiting on pushrods, direct port N2O plumbing, hopefully fire up will happen in about 4 weeks. Which valve covers???
jon
jon
What valve covers are those? I looked on Beck's website, and I couldn't find any pricing info. What did that bad boy cost, and what else did you need to buy to make it work? Thanks!
intake is a BECK sheetmetal, valve covers are moroso # 68352. don't think i'm going to use the moroso ones, i have another set of sheet metal ones that don't have the coil bracket bungs on them. (going to relocate the coils)
jon
jon
What do you want from a cell phone? Just showing the manifold on the motor.
Originally Posted by crazy3rdgen
that motor is very tiny, what is it that I'm looking at here?
I paid 2350 with the N2O bungs installed. A few areas to note: The plenum top arrived bolted to the bottom, but was not sealed with any kind of a gasket. It needs to be seperated, and sealed with RTV. It does not come with a throttle cable bracket. Beck included an aluminum piece so that I could fab one up myself. As for gaskets, he will make it with or without o-ring grooves. The o-ring style left the area around the groove a little thin for my liking, so I went with a paper gasket. Felpro makes a great ls1/metal intake gasket now in several thicknesses.
OWN3D BY MY PROF!
Since I found a recent thread where someone is running a solid roller I have some questions for you.
What valve springs are you running?
What was involved in making them fit?
Just cutting the pockets for larger diameter springs?
What sort of lift are you running?
Did it necesitate longer valves, taller springs, or valve cover spacers?
What diameter pushrods are you running?
What set of et heads do you have?
What's the maximum RPM you'll be running?
Sorry for the bajillion questions. I've been looking into something similar recently and there isn't much data around about the specifics. Thanks.
Heads are ET 245s. Had them build them to solid roller specs. They say it is "their" spring, so I'm not sure who makes it. They rate it good to .700 lift. I bought the heads assembled. I'll be running around .675 lift. Plan to spin it over 7200. Won't know exactly where until tuning. As far as pushrods, I'm gonna try to fit a 3/8. Should know by next week. ETs don't require spacers, due to the raised rail. A stock cover may need to have the baffling removed.
OWN3D BY MY PROF!
LS1 Tech Administrator
Definitely the polished valve covers, but all this begs the question:
Why go to the expense of a sheet metal intake and solid roller cam if you're only going to spin it up to 7200 rpm? It's above 6500 rpm where the sheet metal intake really shows it's superiority over a ported FAST.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
