ALDL cable for LS1 edit
My cable for edit got shut in the door and now doesn't fit worth a crap. I'm worried about it crashing my pcm sometime. Can you use a SUPERCHIPS,ATAP, HYPERTECH cable with edit?
Re: ALDL cable for LS1 edit
What doesn't fit?
The OBDII connector portion?
It's the same pinout as the AutoTap cable (the DB9F to OBDII portion of the LS1Edit cable). We did that intentionally.
If it's your case that's crunched or something, let me know, I can do replacement cases.
-Andrew
-Andrew
No it's the OBD end. I tryed a superchips cable and it said something like "recieve error #4" when trying to read my pcm.
